lost foam core lay up
I’m looking for a foam block material that I can shape and mould, that is rigid, and can be sanded smooth to use as a form by which carbon will be layed over and vacuum applied. After cure the core will need to be disolved. I have seen 2 part water sluable systems, but I want a block of foam (12" squared) to carve into shape, any suggestions?
