Hello,
I am going to make a series of tubes that are about 6 feet long and tapered from .5" to .3". I would prefer to make them out of some biaxle sleeve that I already own but am up for anything else if that is thought unwise. I’ve made long tubes with a large diameter before but never this long and this small. Is there any tips or suggestions for how to make them? Is it possible for infusion with such small tubes? I like the freedom infusion gives but am also up for wet lay up. Each tube will have at least two layers of either carbon, kevlar, or fiberglass.
I am was thinking of making a dowel that is 9 feet long and use that as my mold. Then on the last six inches on the pole after I had layed up the fabric I would make a pair of handle bars on the small tapered end. This way I could clamp the dowel down and use the built in handle on the composite piece to pull it off the mold. Then to finish the piece I would cut off the handle to make it the right size.
When I made my rocket that was 4 feet long and 3" in diameter it was super tough to get off its aluminum mold even with dry ice and liquid nitrogen, I don’t want to have to go through that twelve more times if possible.
