Ok, so I am up for a challenge and want to fabricate a gas tank. I will update this OP with the latest pictures and post questions I have as the fabrication progresses. I am fine at this stage, but I am sure I will have some questions soon.
Disclaimer: I have never made a fuel tank before, so this will be improvised as I go.
I am ramping up the fabrication to full speed with the temperatures warm enough to play with fiberglass/carbon fiber now.
One thing really lacking on these bikes is range – the ability to go for more than a couple hundred miles on the road. I am hoping to make a tank with the capacity of an additional 4-5 gallons is the goal.
You will have to use your imagination, but I would like your thoughts on this. I will figure out these things as I go.
[ul]
[li]The OEM 449/511 seat will fit with minor modifications to the seat.
[/li][li]The OEM 510 plastics will be molded into the gas tank and part of the tank itself
[/li][li]The tank will be made from carbon fiber
[/li][li]The tank is not fitted perfectly and still needs minor tweaks
[/li][li]This is a rough idea of how it will look
[/li][/ul]
