Well, spraying Gel coat failed horribly. Didnt care about the gun first off, had a 1.4 tip drilled with a 2mm bit. harbor freight. had it for awhile. glad i had a backup
So im buying a gel coat gun 2morrow. lets see where i get with that.
I tried to spray, and it worked⌠but not fast enough. then brushed the rest on. i had waited about 20 mins till b stage, and wow, i f-ed up big time. i should of waited till it was fully cured. the stuff was to sticky and when i had to move it, the gel coat came off the mold =(. so i was upset and ripped the fiberglass out. glad it wasnt carbon!
but i gotta say, this stuff is NICE super clear. not to brittle. i gotta make sure my mix ratio is good. it called for 100 / 2% mix. so i had a batch of 4 oz gelc. + .08 oz of mekp. is this right??
well⌠hopefully i can scrape the rest of the gel coat out 2morrow⌠and give it a try when the gun gets in. any tips when its dry and then put the 1st layer on? if its not in b stage, but fully cured⌠i wanna see if airtac2 is a good product.
oh well⌠live and learn i guess⌠i do have a major headache from smelling the gel coat. i even had a mask on =(
just keeping the âspammersâ from FG out is the not so fun part of doing this! :eek::rolleyes:
