just do not see how can a foam core sheet be adapted to the double curvature surface of a flared bow boat mould, for resin infusion, not even using double cut on both sides of the core, and if the core is completely cut it would still have quite widely open gaps that will saturate with resin, if the core has some spring back tendency then there will be a tendency to leave voids that would be filled with resin when infused, so IMO the core should lay perfectly adapted to the shape underneath it when everything is laid down dry, something I just dont´t see happening.
Adapting it heating the core sheets in an oven and then adapting them while still hot is the only way I have found searching the web, but it seems to be a quite cumbersome job, is it there a clear guranteed way how is this done?
The bow section of our mould has a quite severe compound surface, and if we dont find a solution we might be forced to avoid coring the bow area …
