I recently posted on a project that I’m working on (experimental aircraft inner landing gear doors – see: http://www.compositescentral.com/showthread.php?t=7145 ). I’m looking for some last minute advice so this is an update/follow on to the origianal post. See the original post here:
Please see the attached pictures:
http://www.flickr.com/photos/81745619@N08/7482729802/in/photostream
http://www.flickr.com/photos/81745619@N08/7482720818/in/photostream
http://www.flickr.com/photos/81745619@N08/7482730086/in/photostream
http://www.flickr.com/photos/81745619@N08/7482728148/in/photostream
http://www.flickr.com/photos/81745619@N08/7482728644/in/photostream
http://www.flickr.com/photos/81745619@N08/7482728972/in/photostream
At this point I’ve completed the following steps:
[FONT=Calibri]1. [/FONT]Created a skeleton frame using 1/8” x ½” basswood strips over the brake calipers & landing gear half forks (to streamline the areas of the brake calipers and half fork that protrude from the bottom of the wing when the landing gear is retracted). The strips were feather sanded where they contact the surface of the wing and hot glued in position.
[FONT=Calibri]2. [/FONT]Fillled the cavity with A/B mix polyurethane foam (after damming up the wheel well with balsa planks and covering the brake caliper and half fork with plastic).
[FONT=Calibri]3. [/FONT]Sculpted the foam to the desired contour (the basswood strips were my sanding guides… sanding the foam flush with the basswood will provide the required 1/8” clearance between the finished gear door and the brake calipers.
[FONT=Calibri]4. [/FONT]Filled the porous foam with a mixture of vinylester resin and micro balloons (it was shocking how much of this mixture the porous 2 part foam absorbed).
[FONT=Calibri]5. [/FONT]Sanded the resin/micro mixture to get “close” to the desired contour of the gear doors
[FONT=Calibri]6. [/FONT]Applied 3 x layers of 9oz 7781 eGlass (vinylester resin) – trimmed the laminates to the edge of the aerodynamic blister
[FONT=Calibri]7. [/FONT]Mixed up a small batch of resin/cabosil to a paste consistency and applied to the edge of the laminates to smooth the transition to the wing surface in preparation for step #8
[FONT=Calibri]8. [/FONT]Applied 2 x layers of 9oz 7781 eGlass (vinylester resin) – trimmed the laminates to 1” beyond the edge of the aerodynamic blister (in other words the last two laminates lapped 1” onto the wing surface)
This is five (5) layers of 9oz glass or approx 1/16" thick which shoudl be durable enough for a plug.
Next steps:
[FONT=Calibri]a. [/FONT]Sand, fill with bondo, sand… repeat until the shape is perfect (not worried about weight at this point because this is simply going to be the “plug” for my gear doors – 95% of the aerodynamic blisters will be cut away after I’ve complete the female mold off of these plugs) - only the small crescent shaped “door ramps” will remain as part of the wing.
[FONT=Calibri]b. [/FONT]Prime with duratec primer
[FONT=Calibri]c. [/FONT]Sand with progressively finer paper and ultimately polish with a good compound
Since I’m using the wing surface as part of the plug I can’t afford to have the mold not release from the plug… I also can’t use semi perm release on the plug as the wing surface still needs to be prmied/painted at some point in the future.
[FONT=Calibri]1. [/FONT]What kind of pot life can I expect out of duratec gray surfacing primer at 100 degree ambient temp (hot here in Phoenix this time of year).
[FONT=Calibri]2. [/FONT]Do I need to add gloss additive to the duratec primer or is it only added to the gelcoat (as in: gelcoat that I apply to the plugs before laying up reinforcement layers of fabric when building the female molds)
[FONT=Calibri]3. [/FONT]Once I have the plugs primed… what grits of sand paper should I use to progressively sand the plugs… ending with a polishing compound?
[FONT=Calibri]4. [/FONT]What polishing compound works the best?
[FONT=Calibri]5. [/FONT]I don’t want to use PVA so can I at this point apply 5-6 coats of a good release wax (Maguires?) and then proceed with laying up the female mold? As in: Brush on gel coat (I’m going to brush on because I don’t have a gel coat gun), apply reinforcement layers, apply wood reinforcement frame to support flange, let cure and hopefully the female mold will release from my plugs without a hitch.
[FONT=Calibri]6. [/FONT]Ideally the female molds won’t require much prep work before they’re ready to vac infuse my parts (gear doors – constructed of 1 layer eGlass, 2 layers CF, ¼” core, 2 layers CF, 1 layer eGlass… all with infusion epoxy)
Looooooong post I realize but I’m pretty new to all of this stuff so I’m hoping you guys can help me out.
Thx!
James
Phoenix, AZ
