I am trying to figure out what epoxy to get to fabricate an FSAE body and we want to do an infusion since our team members have experience with it. The body panels won’t be too large, but I am not sure if a pot life of even 60 minutes would be able to fully infuse it, so I was looking at resins with 120 minute pot lives but they are a little more rare and expensive with low viscosity. But I have been thinking, is there anything stopping me from either doing two feed lines and opening the second one half way through the part when the resin front reaches it, or just mixing several batches throughout the infusion and refilling the feed bucket? As the resin heats up, pouring new freshly mixed resin should cool it, but would it heat up again fairly quickly? For example, if I needed 3 gallons and I only mixed 1 gallon at a time, then when it gets low, I mix another gallon and pour it in, would that negate the smaller pot life?
Does anyone have a recommended infusion resin with up to 120 minute pot life for $150/gallon resin kit? We did an infusion with uscomposites medium hardener on a panel about 4 plies thick and 12" x 36" that just barely made it before the resin started heating up.
So, my main questions are, is it okay to mix several batches of a smaller pot life resin to accomplish a longer infusion, or should I get a resin with a longer pot life and only mix one batch? And which epoxy would you recommend for $150/gallon kit?
Thank you!
