Laminating in Workshop
Hello,
I am looking into getting a workspace so I can continue to laminate during the winter months. I am going to contact some of the storage unit companies, as they mention that you can rent there units and use them as a workspace.
What I would like to find out is what is a sufficient amount of ventilation needed for using laminating materials. I will mostly be working with Epoxy resin, however, will potentially be using a polyester surface coat (Duratec Sunshield sprayed with an HVLP) for many parts.
I have included some of the material information below.
Epoxy Resin (Aeropoxy 2032 for now)
http://www.ptm-w.com/dynamicdata/data/docs/aeropoxy%20pr2032%20bulletin.pdf
http://www.ptm-w.com/dynamicdata/data/docs/recommendations%20for%20handling%20epoxies.pdf
Polyester (Duratec Sunshield)
http://cdn.fibreglast.com/downloads/SunShield_MSDS.pdf
I will potentially be looking at a unit 10’x20’, climate controlled, electricity. I will need to dig a little deeper to find out the ventilation.
Any input appreciated, thanks!
I would also love to see some of the workshops that you are all working in for some motivation!
