Given that someone uses common RTC epoxy resin, do you think that a moderate heat post cure will add something on the thermal stability/strength f the final part?
Do you think that a moderate heat post-cure will make a part capable to withstand temperatures of about 100-150C (200-300F)? ETC resin is actually super expensive!
Read the specs.
Most resins that can cure at room temp don’t hold up well past 150-200* F. Post curing helps in most cases, but won’t give the resin any properties it doesn’t already have. For rtc’s, a post cure of 150*F usually adds stiffness and a little more strength. Keep in mind a lot of resins will change colors too.
