I have just made a mold for a sunroof panel. The panel popped out and the mold looked good but I used the green kitty hair bondo as a filler and once the mold was out it delaminated from the resin/csm. I am wondering if there is a way to prevent this?
As well, is there a filler i could likely find in my garage that would work well and be sandable. I have heard of using sand but I have a feeling it would cause problems when sanding. I have tried using sawdust but it just doesn’t work that well.
Yet another…the whole plastacine thing…do you leave the plastacine that you have fitted to the edges of the part in the mold or do you remove it and fill after? what prevents the plsticine from changing shape once molded if poked???
As usual, Werksberg is the place to go for composite learning!!!
Thanks guys
