Just finished up a minimalist wallet with a composite spring
It’s called a cardbow. It’s in the same vein as the minimalist wallets but but is unique in that it uses a composite spring instead of elastics and metal.
There are way more pictures on the campaign page.
https://www.kickstarter.com/projects/1106663250/cardbow-perfectly-hold-the-perfect-amount-of-cards
I’ll answer any questions I can about the layup and processing of the spring. Which was all done in house.
Interesting… kinda of the opposite approach to something like the billetus
looks clean. Though I think it looks very flimsy… but it’s made of silk so i would think it’d be supple. ANd why is it narrower than the money it holds? the contents don’t have a tendency to fall out?
Good work, your project is on it’s way. With 36 days to go you should make it there.
Looks clean. How did you made your lettering?
