Hello Composite Central! This is my first post, so be gentle!
I am an enthusiastic amateur when it comes to composites. I have done some repairs/modifications to a boat using vinylester/tapes/Q-cells, and used bondo/bog on car repairs. But my next project is a little larger - like a 12m bus shell!
Due to space/weight constraints (not enough room for a 12m mould, and the panels would be very difficult to move/store/install) we have decided to manufacture approximately 30 individual panels - 10 for the roof and 20 for the walls - which will be joined and flushed when the panels are installed on the buses frame. Each panel is approximately 2.4m by 1.2m.
With some help from the supplier of our raw materials we plan to construct the panels from polyester resin, a single 3mm Coremat layer, 3 x 450g CSM layers and a 450g biaxial fabric/225g CSM combination fabric layer. We think we might have over specified the panels construction - what do you think? :wondering:
We have produced some one square metre panels using the materials mentioned above and did some very non-scientific impact and bending tests on, and were very impressed. For interest, the largest span between steel members in the buses frame is approx 500mm.
I understand that a lighter panel of equivalent strength could be constructed with vinylester or epoxy, but cost is more of a driving force than weight - and the weight of the metal “skin” we are replacing was substantial!
To enable the individual panels to be joined - we have access to the external surface ONLY - we came up with a multi-step recessed edge. I think a single stepped edge is a known as a joggle - I guess you might call this a triple joggle? We are planning on using epoxy to join/glue the panels together and, at this stage, at least a single layer each of 50mm, 100mm and 150mm tape. I say at least a single layer, because more layers might be used to end up with a close-to-flush final tape layer, to minimise the filler needed to flush the panels external surfaces.
Is this triple joggle overkill? Would a double joggle be sufficient? Perhaps using 100mm and 200mm tape?
I look forward to your replies and suggestions!
