For the top layer, I have created an artificial “V” pattern using two 50" pieces of carbon. Just as a process note, I was also using a layer of clear gel coat and infusing with VER. You could do the same with epoxy and tack spray. First, find the center line of the piece. Then, I cut a piece of peel ply in a straight line that acts as a mask for the side opposite where you are going to lay down the first side. I then make sure the carbon, 2x2 twill in this case, is oriented in the desired direction (flaring from center out, front to rear) and lay it down over side “A” (the first side for lack of something better to call it). The gel coat or tack spray will hold the piece in place and it will not stick to the other side because you have the peel ply there. When I lay the piece down, I also make sure that it overlaps the center line so that I can fold the material back over itself. When folding it back, you need to pay particular attention to getting the seam or fold as straight as possible or it will not look as good. You can use tack spray to hold the flap down flat. Then, remove the peel ply and lay the second piece down with a mirror of the opposite side. You dont have to worry about folding it back over itself because you will not be able to see anything from the other side. If I use an analogy, its kind of like folding a paper airplane if you get what I mean. Hope that helps and did not totally confuse you.
