my plug is almost done, then flange time and molds.
this post pertains to the layup schedule for the final part and whether to use a core material or not - would like to build the whole hull out of carbon.
i have one buddy who used 15 layers of 6k/11oz carbon fiber, alternating the weave pattern between layers. costly, but has held up for him. i have another buddy who used coremat as a core material, but he stated after a few seasons it started to delaminate inside the engine bay.
others i have spoken with who have worked with core materials (i personally never have) said stay away from a core material for the bottom of the hull for fear of delamination. i was thinking of using 1/8" Divinycell though as i know one reputable builder is using it (wouldn’t say where/how), his hulls are SUPER light and strong (but he won’t give out his layup schedule which I totally understand as he is business to make money, I am doing this for my own personal benefit).
i know a lot of large boats use a core material, but most hulls are V shaped whereas this is more of a flat bottom.
i plan on building my first hull out of 12oz biax to “season” my molds and figure out the best pattern for the layers (that and it will be cheaper/safe to build as my first part and i have a layup schedule someone else has used that has worked for them).
after that i want to do the carbon hull. weight and strength are the two agendas here. i plan on vacuum bagging. infusion would be cool, but i do not have enough experience in my mind to jump to that.
wondering what weight fabrics, weaves, core material or core material?
i know the top and bottom with by completely different layups. the bottom is what i am most concerned with as it takes the most abuse, and the motor/pipe will be attached to it. i plan on building some test plates, but even with a small test plate, it is hard to know (for me anyway) how it will work on a much larger part.
thanks all for your time / input.
-Andrew
below are pictures of my hull before turning it into the plug:
