Well i’m having some issues with pulling a perfect part from my mold and i’m hoping someone can help me out.
I guess the easiest way to determine the issue would be to outline my process…
I am making pipe guards for bikes using high-temp epoxy.
I have made a mold which is perfectly smooth and I have had no problems releasing my parts from now that it is properly waxed.
Basically, I start by mixing up a batch of epoxy…this stuff is really thick! I brush on a layer of epoxy when it is nice and thick, into the mold. Then I put down a layer of carbon in the mold, press it down, then heat up the epoxy in the cup with a heat gun so it is less viscous. then I brush on epoxy into multiple layers of carbon, fiberglass and kevlar. Then put in release cloth and finally absorber cloth. Then I bag the part, and am getting a very strong vaccuum.
After I release the part, it comes out nice and strong, pops out easily.
The issues is…When i release the part it has a number of small pinholes and also a few bubble-filled areas on the part.
I need to figure out how to eliminate these pinholes and bubbly areas from my parts…
I would really prefer not to have to spray a gell-coat on the mold as I beleive the epoxy is too thick and have no way to spray it.
Any suggestions would help!
