I’ve been having this issue with little micro bubbles getting stuck between the threads of carbon, but only on parts with an IMC. Picture 1-2 show the issue close up. Picture 3 shows the issue overall. These are all from a part that is laid up over a clear IMC and done by infusion. The last picture is a close up of a part laid up direct against the mold surface. Same infusion epoxy, same setup, same cure temp, same everything. I’m just having a hard time figuring out why parts with the IMC are giving me this issue. I have never had to de-gas my epoxy (the last picture was done without degassing the epoxy and it looks fine) and I did already try to degas the epoxy on another part and didn’t turn out any better. Any help would be appreciated.
IMG_2529 by AJ Hartman, on Flickr
IMG_2528 by AJ Hartman, on Flickr
Overall you can see it makes the part almost look “cloudy”.
IMG_2530 by AJ Hartman, on Flickr
Here is the part laid up just against the mold. No IMC on this one.
IMG_2531 by AJ Hartman, on Flickr
