I am trying to understand the cost and complexity impact of external vs. internal (returned) flanges. In the conceptual images below the red shell has an external flange and the yellow has a returned flange. The approximate dimensions are 90” long x 60” wide and 30” high. The flanges are about 1”. The outside surface is polyester gel coat and the overall layup (CSM and cloth) is about 1/8” thick. Corner radii are about 1/2” max.
http://i250.photobucket.com/albums/gg272/robrien24/ExternalFlange.jpg
http://i250.photobucket.com/albums/gg272/robrien24/InternalFlange.jpg
The external flange is simpler to make but would be far less attractive than the returned flange. I’m not really sure how the returned flange would be made although I assume the flanged portion of the mold would be a separate piece so the part can be released from the mold. Is it better to attach the flange surface to the mold and then mold the part and flange as a single piece or is it preferable to mold the shell w/o the flange first and then add the flange as a secondary operation.
Any insights would be appreciated.
Thank you
Rick OBrien
