InstaMorph Mold
Does anyone foresee a problem with using InstaMorph plastic as a really quick mold material for a one-off protoype?
Doing a bit of googling, InstaMorph is actually polycaprolactone
(http://en.wikipedia.org/wiki/Polycaprolactone).
The only thing I’m worried about is the resin exotherm locally heating the “mold” enough to deform or melt and any possible epoxy interactions (I would be sealing/releasing with Frekote).
Unless anyone can think of a major issue, I’ll just try it and report back. If it sticks I can just dunk it in hot water and scrape the mold off the part!:smiley:
Depending on what the melting point and pliable point is for that instamorph stuff I’d almost want to consider doing the layup in a colder temperature atmosphere. Or if doing infusion boarder line temperature for max infusion/workable time, but in the second case you’d have to really know your epoxy or resin and what’s the coldest it can be while still workable.
I posted about the instamorph stuff while ago about I think plug making but still have never tried it. Interesting looking stuff though.
From what I can tell it has quite a bit of shrinkage during it’s setting. I will not reproduce make a female mold with any great degree of fidelity.
