Hi guys,
I believe I have read almost all possible threads on the topic but still having issues…
See picture for my voids issues…
Is this “Intra Tow” or “Inter Tow” voids? Voids or air pocket?
My process:
0. In mold Coating with Duratec, wait for 7h for no more (or barely) tack
1.Layup:
1.1 (3) layer of 3k 200gsm 2x2 twill carbon fiber, using some Airtech Spray adhesive but only between carbon layers where needed.
1.2 Peel-Ply (Econo stich) (I tried without and same results)
1.3 Infusion grade Perforated release film (I tried without and same results)
1.4 Flow media (sometimes using green flow, and some other time using a “nylon knitted version”)
1.5 Double vacuum bag to reduce perforation 28.5/ 29 inHg
2. Apply vacuum for 15min, ensure absolute no leak
3. Mix Adtech 820/823 (350cps)
4. Degaz for 10min the resine at 29inHG. “Air seeded” with Scotch Brite.
5. Let infuse the resine (using 3/8 spiral tube): I tried slow speed (1in/min) by restricting the resin inlet and fast (+5in/min). Same results. Note: The inlet resin reservoir is at same height as the mold.
6A. Close the vacuum first wait 30sec then close the inlet
6B. I also tried closing the Inlet first, wait 30 sec and then close the Vacuum… Same results.
Note: I do have a “Peel ply” “break zone” around 1-2in before the vacuum tube to slow down everything and let underlaying resin catch up.
Shop conditions:
Temp: 79F
% Hum: 32%
No matter which condition I seem to be using I cant get it without those voids… And since I am doing In Mold Coating, those voids can not be repaired as they are caught between clear and carbon fiber…
Any brilliant idea??
Is it something to do with Intra-tow Capilarity flow speed and inter-tow flow front speed?
Tks!!
