Hello!
I plan to try some infusion work and would like som input, it seems like there are quite a few things that can go wrong if you don’t know what you’re doing.
I am doing tubes, 40 mm in diameter and 60 cm long. You can see a sketch of my infusion mold in the picture. I plan to use a pressure bladder inside the mold, simply a cut road bike tube with release added.
One inlet, one outlet. Edges of mold will be sealed off with a double row of mastic tape. The mold will not be transparent, I will cut the flow when epoxy meets resin trap.
Will it work like this?
would you do it differently (how?)
Do i need some flow media?
I’d really appreciate some input!
Cheers /Lars
