Im prepping a new mold for infusing a carbon fiber part.
I started using these Toro sprinkler T’s a few months ago because they fit 3/8" outside diameter tubing perfectly. I get them at Lowes for .65 cents each. For this set up I don’t need or want to pull vacuum around the entire perimeter of the lay up. I chose the area where resin will flow the slowest, around multi radii tight areas as seen in the photo. I pull vacuum from that end of the mold. I made my own spiral wrap with a utility knife and polyethelene hose. I’ve found that when using 1/4" I.D. vacuum tubing that I need spiral wrap to pull sufficient vacuum under the vacuum bag. That and my resin is 600cps so it doesn’t infuse as quickly as say a 300 cps resin. More vacuum area is needed to pull that heavier resin thru the laminate and flow medium. I’ll run a test later with the red flow medium vs. the green i now use.
Anyways I was just hoping that these photos would help someone out with their own project.
http://s210.photobucket.com/albums/bb186/Fastrr_photos/?action=view¤t=000_1201.jpg
http://s210.photobucket.com/albums/bb186/Fastrr_photos/?action=view¤t=000_1203.jpg
