When comparing infusion epoxy specs to normal laminating epoxy I was surprised to see that the infusion resin looks better even before post cure. Looking primarily at the strengths, and elongation. I was under the impression that you gave up some strength / stiffness when going to the lower viscosity.
For some time we have been using a thick 900cps resin for wet lay vacuum bagging. We switched to the 900 from a 600 because of the better properties. It would be worth the extra cost if we could get even better properties from a thinner infusion resin. Would there be any problem with using a infusion resin with wet lay vacuum bagging? I have been practicing infusion but it may not be right for all of our parts.
Does anyone have a suggestion for epoxy infusion resin in the US in single gallon quantities? So far I am looking at MAS, adtech, pro set, and composite envisions. Composite envisions will not publish the strengths / elongation so they are last on the list.
We are building 30’ long 15" wide racing hulls. Typical layup is 3mm foam sandwiched between 5oz carbon.
