Hi there, im trying to find a good resin feed line material as i want to get away from using spiral wrap. The spiral wrap leaves a resin rich blob on the part which is annoying to grind off afterwards, so im looking for a material thats cheap, easy to lay, and is flat so theres no mark off - similar to the enka channel or resintrak products designed for this purpose.
So why not use the purpose designed products? Because theyre too expensive… ive managed to cut my infusion consumables cost by 300% by using other materials that are designed for other purposes, not resin infusion consumables. The resin feed channels is the last thing i need to figure out.
To give an idea on consumables savings, i am now using the following;
Vac bag film = polyethylene shrink wrap film, no holes, rolls 4m wide x 100m long = $100 per roll = 400m^2;
Flow media = ive used everything from bird netting @ $100 per 450m^2, to shade cloth @ $0.30c m^2 to plastic mesh/netting depending on the required flow speeds. Many fabrics and plastics are available.
Under bag Vacuum lines = Hessian Webbing for tieing plant saplings @ 20c linear meter.
Hoses and plumbing, all has been adapted to use std PE irrigation tubing and fittings hardware - no it doesnt leak or collapse under vacuum.
So does anyone have a solution for low cost resin feed lines that will not mark off? Ive tried a few things and they work, but they do not flow fast enough to suit my purposes. I typically infuse parts between 20-40kgs of epoxy over 10-20m^2.
