Hi all,
My first post on this forum !
Since 1 year, I made stratification composite with vaccum bagging. My results was really nice, no pinholes, perfect surface.
But after saw many videos on the infusion, I wanted try this technic. I bought infusion mesh and resin for infusion.
So I have made a mould, using black gelcoat with aluminium. I polished it, put 1 layer of PVA and 5 layers of liquid wax and polished it again.
This is the result of my mould:
A guy who is suscribed on this forum, helped me for my first infusion.
We put:
1: 1 fine layer of spray glue
2: the first layer of carbon (193gr/m2)
3: a second layer of carbon
4: 2 layer of kevlar
Each layers have been glued with the spray
5: 1 layer of peelply
6: 1 layer of perforated film
7: 1 layer of infusion mesh
8: 2 demi circular spiral tube, 1 for resin, 1 for air.
9: 1 layer of vaccum bagging
My vaccum pump only give me -0,75 bars.
We make the vaccum and we prepared the resin. We have put the resin pot under the level of the mould and clamp the tube. The tube for air and resin is Ø6 mm.
This is the moment to remove the clamp on the tube, the resin entered in the mould and after 10 minutes, all the mould was full of resin. The excess is gone out on my catch pot. After several minutes, I have clamped the air and I have put my part in my oven for 12 hours at 60°.
I have demoulded this morning, two layers was too thin so I break my part, so it’s only a test !
I have try to release the rest of my part from the mould. The result is not good, I have many pinholes. We don’t understand why because the guy who helped me for this test make some beautifull parts with success with the same technic, so where’s the problem ?
Is my pump don’t give not enough vaccum ?
What I’m doing wrong ?
Thanks.
