I infused a part last night with a funny shaped core in it, so I wanted to give strechlon a shot. The part is kevlar and glass with a divinycel core that I scored every 3/4". The stack after the part consisted of infusion peel ply, green flow media, and the strechlon. I wrapped the spiral wrap in peel ply because it usually allows the resin to get to the ends of the wrap before infusing through the part. I did a leak check on the part prior to the infusion and it held vacuum with the pump off. I did this twice, once with the vacuum source on my resin-source T-fitting with the other side blocked off with sealant tape, and once with all lines in place and the source line clamped off. The results were the same. The resin used was PTM-W PT2712 w/B hardener (60 minute geltime at 77F).
15 minutes, 1/2" drop
25 minutes, 1" drop
I figured I was good, so I started infusing. Immediately I’m getting air bubbles that I find to be the resin source T-fitting and fix it immediately. Why would that show up THEN and not during my 25 minute leak check? In either case, although I’m pulling 26" the bag is now bridging on all the radii, and every radius has about a 1/8" pocket full of resin and air that aren’t making their way to the vacuum source. Under the vacuum why would that not suck down? The resin/air combo seemed to fill all of the radii and just hang out there while the remainder of the part infuses air bubble free. All the bubbles seemed to work their way through the bag when I applied a heatgun to the radii of the bag. The bag was also slowly sucking itself into the radius, before I got the bag too hot in one area and suddenly lost all vacuum :). I popped the bag, but at that point I was just gathering data.
This was all done in my garage, not the shop, at 55degrees F. Sooooo here’s what differed from my conditions in the shop where I do awesome infusions. Let me know what you think it might be.
1)I used stretchlon (800), instead of my usual ear-extraveganza bagging material
2) It was 55 degrees F, and I did not get the resin up to 77F. Possibly it wasn’t viscous enough to really let the air bubbles escape? Once I heated the resin/bubble rich areas, I got back my compaction and the air bubbles slowly disappeared.
3) I was using a 2.5 cfm pump. Once I introduced air bubbles, maybe i didn’t have enough cfm to crank down the bag quickly enough?
Sorry for the wordy post.
Pics:
first debulk/leak check
Resin rich bag, with resin filling all the radii
Closeup of frothy resin rich area.
Any thoughts/ suggestions? I would like to be able to do some work in my garage for small personal projects.
