Hi, I have a question about infuse a panel and if use infusion mesh .
At the time of you infuse a panel, resin in the mold side flows worse, the resin flow is much smaller, then, Is it good use infusion mesh on top skin?.
This will make exists more difference between top resin flow and mold skin side, when ideally would be that flow top and down be equal.
Specifically I’m trying to make a 80kg/m3 10mm panel with a triaxial glass layer 917G / m² and 2x105g / m² plain in the top and lower skin.
Then, Do I use infusion mesh on top skin?, also I think that my infusion mesh is high flow.
Regards and thank
