Even though my part came out fine I had a few issues that popped up during the infusion… maybe you guys might have some ideas on what to do in some of these cases?
forgot the MTI hose changed so i had issues until i remembered to vac the bag first from another port. This becomes an issue later on…
The draw on the resin was fast then slowed down a bunch to the point to where i was worried that the resin would cure before finishing. the resin is about 350cps. it took about 50min to infuse the whole thing. what would cause this? Only glue i used was the airtac 2 which is meant for infusion.
towards the end, the pump started to act up and let some air in (was low on oil). i fixed it but then the mti hose wouldn’t pull enough air out of the bag to pull everything back down. i had to put another hole in the bag with a separate tube to remove all of the air.
i think i have some print through but i am not quite sure what that looks like… any one have pics? I attached what i think is print through on my part
The part also came out pretty dull (like all of my parts). do you guys generally clear coat afterwards or do an IMC with 2k? I am a little hesitant to spray a clear since i have never done it and the random pin holes also might cause issues.
also can you guys suggest a black putty for filling the pin holes?
lol,it actually probley is alright…
