Hi guys,
I’m getting this bridging like issue and I don’t know how to resolve it. I’ve attached a photo of my mold and the part that is being pulled from it. The infusion is done down the longest dimension, from ‘top to bottom’ in the mold picture, and this bridging issue is occurring at the rounded edge at the ‘bottom’, at the vacuum draw side (as opposed to the resin feed side).
I can’t figure out why this area isn’t being filled in with resin. W/ the way my infusion mesh is set up, any entrapped air (I’m pulling 29" vac) would have an opportunity to evacuate that corner before becoming sealed in.
I am pretty sure that the fabric is sitting very flush against the molder surface as I have a template to push it into place before I pull vacuum down. It also only happens on this side, and not the corner at the resin feed side, which would have an equally likely risk of not sitting flush since they’re identical curves. This has happened a couple of times so far.
This side is near the first ‘uphill’ portion of the mold; the resin feed side corner that comes out very well is a ‘downhill’ and then flat part and is about 5cm away from the resin feed inlet.
Is it a resin viscosity issue? The only thing I can think of is that the resin feed side floods quite easily since the it’s so close to the feed; the resin is moving quite quickly at this point. By the time it makes it all the way over to this side it’s moving at about .2 cm/second. Temp is about 70F, resin system is Adtech 820. Resin inlet valve is open for quite some time after this area is initially wet out though, it’s not like it’s shut off a couple of seconds afterwards. It’s usually open for at least another minute, although the draw is occurring much more slowly by this point.
I’m pretty stumped. This is the 5th part I’ve tried to pull and each one has some variation of the bridging void. I would’ve thought this entire void would be filled in with resin under this much vacuum.
Any input is appreciated, thanks.
