Im having issues with an infusion that Im doing. The mold is for an ice hockey goalie mask. I dont have any pictures but the general shape of it is a wedge. I am using spiral wrap all around the perimeter flange and have my resin inlet at the center of the mold.
The issue that Im having is that I seem to be losing compaction right at the center of my mold. The laminate I have is the same through the whole piece, however the layers near the resin inlet are not being compacted as much as the perimeter. The laminate properly infused should have a thickness of about 1/8 of an inch. However the laminate gets thicker the closer it gets to where the resin feed is.
I do not have any vacuum leaks that I can detect. The only thing I can think of is that my resin inlet hose is too big. I never had a problem with this before, but excess resin seems to pool right at the resin inlet before the resin can spread out to the rest.
Im using a 3/8ID inlet hose which I think might be causing the issue. Would an inlet that is too big cause issues like this? I wanted to see what other guys thought before I tried this with a smaller inlet hose.
