About Airtech AT200Y and AT199, and sealing in general:
So far, with the aid of a leak detector, I never have been able to not seal a bag properly, whichever tape used. I use Terostat 81, Ce-Sense Sealant tape (our own product) or Airseal 2 by Airtech, and they all do the job. I have even been able to seal a bag properly using a 10x1mm sealant tape (roughly 2/3 the with and 1/3 the thickness of what is normally used).
What is critical is fiber pollution. Always clean the flange with a rag before putting tape down. Perhaps even twice. And use the leak detector. (whichever type). I will see if I can offer a good deal on them. Lot of companies make a lot of money on them. Leak detectors sometimes even surprise me for finding leaks I could not imagine were there.
If you find a fiber protruding from the tape, fold back the vacuum film, stick another piece of tape over the edge, remove the backing, and fold back the vacuum film again. This usually does the job.
If you like double seams, make sure you apply a piece of permeable material between the 2 tapes. This could be anything, a piece of rope, a strip of bleeder, or some tube mesh, which we sell specifically for that purpose. Then apply a higher vacuum on the so created double seam. If a leak occurs, it will get solved by the high vacuum between the tapes. The same principle is sometimes used when bagging for a 100% void free carbon mould, where not only the tape seam is double, but the whole bag, with strips of bleeder every 30cm between the double bag. It is a lot of work to setup, but it assures a perfect airtight bag.
