Thank you. While you’ll find different thoughts on this process, I have my own. The carbon fiber version was done with PVA, no clear coat and epoxy resin. I’ve been using the 3M 77 spray adhesive although there are probably better choices for epoxy(I forget what it’s called) I actually used the 3M 77 on the PVA even though it’s delicate. It was fine and aside from the mold capturing the part a little, the part was removed without hassle. You can see the PVA still on the part in the picture with some areas roughed up from us handling it.
As far as placing the “surface” piece of fabric. All I can say is, keep the spray tip on the 3M 77 very clean, use a very fine quick shot for mist and at a distance to keep any “spitting” from reaching the mold. It’s tedious but it works. I’ve never had a “goo” on the surface issue like I’ve read about. Also I spray only as I go.
If it helps - on that first layer, I find the “y” axis so to speak of the mold, drape or fold the fabric and lower it into place along that axis. From there I lightly tamp the fabric into place from the center of the axis, front and rear. Once I have that middle section in place, I’ll allow one side of the “x” axis to relax over the mold and begin working the other side from the center outward using a light mist as I go. At this point I’m usually misting the fabric and not the mold. once I’ve established the one side of the x axis line, I’ll work from that line forward and rear until the fabric is down out to the edges. Repeat on the other side. This jet ski part has a “return” or reveal on the edges so I seated that detail after the fabric was placed out to the edges all of the way around. I trimmed from there and just followed the same process for the other layers. As far as bridging, you have to work from the center of your x and y axis outward. You can’t get ahead of the seated fabric. When you do, you create the bridging. Relief cuts in the tight or inversion areas is the other side of dealing with it. You’ll just have to figure that one out through trial and error.
I used the same process on the kevlar version even though I put a clear coat in the mold. I did the kevlar part at the house as homework. I was sippin coffee and blabbing with my Mom who stopped in to see my little boy all while placing that first layer. Patience gets it.
The guy who owns the mold has been working on building his own parts from the mold with infusion and has been very successful most recently using the same process. He just built one with a plain weave that looks great. I was in a hurry when I saw and didn’t think to take a picture.
Hope this answers your question. Been a long day…!
