Hello guys, i recently signed up here hoping to find some answers reading the topics but i now i have to ask you, hope someone will be willing to help with an advice based on experience.
First, to introduce my work a bit further… I am from Serbia and work with composites for 4 years now, you can have a look at my products here:
http://www.gonzaracing.com/forum/viewtopic.php?t=10366&start=0
http://www.facebook.com/pages/DESIGNPERFORMANCE-carbon-composites/107646032591560
These pages are in Serbian, but if you look at the photos you can see what kind of production it is.
-The problem i confronted came with a request of my customer for mat finish part with carbon appearance.
First i made a bonnet as i normally do:
0.3mm thick gelcoat (NORPOL NGA102S - polyester gelcoat from Reichhold)
Resin infused carbon laminate with DION 9102 - Infusion vinyl ester from Reichhold
after demolding it was finishet wit MaxMeyer mat lacquer
The finished product looked perfect indoor, but in the sun it has Bluish-Violet apperance-shine under certain angles.
Then i ordered other type of gelcoat, which Reichold claims is the clearest available (NGA116S) and got the similar result just less Violet. Note that these gelcoats are UV-stable, and really are (have couple of bonnets made from this standing in the sun for almost three years now.)
-After that failure i started making little A5 size flat samples and from that study i made a few conclusions.
-Mat lacquer it self is not a cause - some other parts that my client had and which were ordered from Seibon, had the same treatment and do not have Violet shine but they are slightly yellow as they werw probably made of resin which is not UV resistant.
-Samples infused with epoxy, and polyurethane instead of gelcoat did not show Violet shine. Than i added Aerosil to polyurethane (aerosil is standard ingredient of polyester gelcoats) in order to get better spray on properties (pinhole or fisheye formation and avoid dripping on vertical parts of the molds when applying thicker coat.) and found out that PolyUrethane Clear with aerosil does give a slightly bluish appearance. (Polyurethane was PPG Delfleet)
NOW i want to solve this once and for all, so i will be running another series of samples, and hope that someone could give an advice or suggest what else should i try?
Note that parts have to be aesthetically perfect and stay like that for at least 3 years.
I prefer VE resin as it cures easier (room temperature), and -from my experience- has better heat resistant properties (does not become like rubber with temperature increse, tested at 80C - parts which were post cured before test) Epoxies i used so far were from R&G and ELANTAS.
I hope someone could help, forward thanks!
