Hi,
MY SETUP
I have a vacuum infusion process set up with a medium-sized dual stage rotary vane pump. I’m infusing a wing that’s 1 meter long and 30 cm wide as a test.
The core is a styrofoam positive wing mold that will remain in the final product. Over that I place the fiberglass. Then the perforated film, breather fabric (http://www.fibermax.eu/shop/breather-fabric-vc014-p-175.html), flow fabric (http://www.fibermax.eu/shop/flow-fabric-vc017-p-176.html) and then the vacuum bag, sealed by vacuum tape.
Along the both of the longer sides of the wing, I place a spiral tube for vacuum and resin flow, approximately 2-15 cm away from the part edge with the flow media reaching the spiral.
My resin is a thin nicely flowing resin and a 2h hardner.
WHAT HAPPENS
When I turn on the vacuum pump, it pulls the resin nicely and evenly across the entire wing. Then about half way through it slows. Then it slows even more.
In the beginning the resin goes under the perforated film nicely, but then just some dots get through without connecting and then, in the worst cases, nothing.
Even if the resin has reached this stage and essentially is standing still, standing it on a side with the inadequate wetting on the bottom will help - gravity will do the rest and wet out the fabric. But only if there’s plenty of time and with plenty of experimentation.
THEORIES
- Not enough vacuum. Though my manometer shows 200 mbar between the pump and resin trap.
- Not enough flow. Perhaps the pumps small reservoir and resin traps holds some vacuum and that pulls the beginning faster. But that doesn’t sound very sensible - if the pump was able to pull the beginning nicely, why not the end.
- The flow media is pulled down so closely that it imprints itself into the styrofoam underneath and doesn’t allow the resin to flow. But in this case, why does gravity help and why isn’t there an imprint on the glass itself?!
- Other - help me out!
I’ve tried it on many-many parts of different sizes and the same thing nearly always happens.
Ideas will be much appreciated!
