I did an infusion tonight, and the result is some dry spots on the mold side of the core. My layup is:
2 plys carbon (5.9oz 2x2)
5 layers glass (8.8oz 2x2)
divinycell core (w/ holes drilled on 1.5" centers)
5 plys glass
2 plys carbon
I have never infused 14 plys before, and the end result was some dry spots on the mold side of the laminate. The part is a splitter for a race car. Aesthetics aren’t important, so I’m hoping to salvage this piece. I have attached a picture of the mold side for reference. My “mold” is a double pane sliding glass door panel, so I had the advantage of being able to see through before pulling the part from the mold.
How to repair this? I was thinking maybe pull it off the mold, then put bagging tape around the dry area on the mold side, and try to infuse it. Not sure if the resin would really wick into the dry areas though. Other thought was to use some resin and heat it up quite a bit to get the viscosity really low and just brush it in or roll it. Thoughts on how to salvage this layup?
Thanks!
