Hi all,
I’m planning on infusing a 100cmx100cm (40"x40") flat panel tomorrow, but i’m wondering if I’m able to do this with only one feed line. I’ve only done small parts, and 30cm takes about 2 minutes to infuse, but slows down near the end. pot life is 120 minutes, so no rush, I just don’t want the resin to grind to a halt.
Could I use 2 layers of mesh or do I run the risk of the resin going too fast on the top and trapping pockets of air at the bottom?
lay up:
- +45° 200 gram carbon fibre twill
- -45° 200 gram carbon fibre twill
- -45° 390 gram glass fibre twill
- +45° 390 gram glass fibre twill
