So I’ve run a couple of infusions so far. Using CF/CSM sandwich and PER from Fiberglast. The CSM serves as my flow media in-between the layers of carbon. On a couple of them, I’ve been about 75% infused when a leak opens up in my bag. This is after I’ve done a ten minute leak test and lost no more than 1" Hg. Both times it has been near one of the tubes penetrating the bag. So I must be doing something poorly where I send the tubing into the bag.
My approach to date:
- Lay my tape down all the way around the mold flange.
- Then wrap a piece of tape 360-deg around my vac tube.
- Peel the backing off all the tape, and stick the tube tape right onto the flange tape.
- Then roll the tube back and forth a little bit until the angle b/t the tube tape and flange tape is closer to 90 degrees.
- Then put the bagging film on.
Is there a better, more reliable way to get a good seal here? I’d love to see pics of how you do it. So far, only one piece has been ruined by losing vacuum. I was able to salvage the others with some really quick scrambling with some sealing tape. =)
Cheers,
Jeremy
