The air in the resin feed hose gets sucked into the laminate when you release the clamp to begin the resin infusion. On a couple of small parts, it appears the air has gotten trapped against the mold and left pinholes and larger voids in the laminate. Has anyone else noticed this, and what was your fix? My resin viscosity is around 300 cps and I have a full vacuum on the part with no leaks.
The reason I suspect it’s the air in the feed line is that the number and size of the pinholes gradually decrease the farther you get away from the resin feed.
TIA - Bob
