Hi all, merry Christmas!
First post here, I’m stuck at work on christmas so this is the most productive thing I could think to do.
I am looking for some advice on vacuum infusing a carbon fiber ukulele shell. This will be my first experience with infusion, but I am very comfortable with vac bagging wet layups (surfboards mostly). I have previously made one from this mold using a vac bagged hand layup, and I was not happy with the process or results. In a nutshell, it was too messy, and the fitting of release film on the inside of the mold after applying the epoxy was a nightmare.
Here’s a photo of the part to be molded:
Maximum width of the body is like 10" if I recall correctly, and length is about 26".
I already have some infusion resin, resin research 2070 (800 cps), and most of what I think I’ll need for the bagging.
I’m planning on doing 5-7 layers of 5.7oz carbon twill fabric.
My question mostly involves how to set up the vacuum, flow mesh, infusion port, etc… for ease of execution.
The problem I run into in my mind is laying down the peel ply and flow media on top of the dry stack. The twill CF drapes very well, but the peel ply and flow mesh definitely won’t. The only way to get those to lay flat inside the mold would be to make a bunch of relief cuts and use small pieces, but then I’m looking at a nightmare to remove all that stuff from the finished laminate, plus it’d be impossible to avoid overlapping pieces. I’m not hugely concerned about the cosmetics of the inside of the laminate, they’ll be mostly hidden by the top of the ukulele… HOWEVER, the cosmetics of the last one I did were BAD (stuck chunks of breather, big lines from pleats, pools of resin), so I’d like it to be a bit better at least.
Could I get away with just using a flow media on the flat wide part of the body and let it just infuse through the carbon the rest of the way, taking vacuum all around the perimeter of the mold? Where would you suggest placing the vacuum ports and infusion ports? Other ideas/suggestions on making this work as efficiently as possible?
Great site everyone, thanks for any and all advice, and once again, MERRY CHRISTMAS!!
