First of all, the layup tooling needs to have locators to properly align the various sections, and good fasteners to hold it together.
Apply release agent to all “A” side surfaces. This includes the flanges that will face each other when bolted together. DO NOT apply release agent to areas where the bagging tape will be applied.
Apply a bead of high quality sealant (silicone is common but not always allowed) to the flanges that will be joined, about 1/2" away from the layup surface. Make sure to go around the bolt holes and it would be wise to add another bead a couple of inches below the first as extra insurance.
After assembling the layup tooling, some sealant will be squeezed onto the layup surface, wipe it away to produce a flush joint line.
Let it sit until the sealant cures, then infuse as usual.
