A question from Tom in the MTI hose thread, which I repeat here, to maximise exposure:
Also reposted the picture which brought up the question:
My answer (others: feel free to add to this)
There are a couple of solutions, and it depends on the mould size and possibilities which solution can be used:
-envelope bag the mould. This is by far the simplest solution. Hardly needs explaining.
-bolt the (polyester) moulds together with sealant tape between the flanges. The disadvantage is that size tolerance is a bit off, and a seam may develop. But it can be enough to succesfully infuse. I would definately like to do a leak test before doing any work in the mould, but actually this is seldomly done.
-a further development on this is a recess in the flange, which is roughly 2/3th of the thickness of the sealant tape used. This makes it possible to mate the mould halves exactly, so the seam is closed.
-the same can be done with inflatable silicone profiles (D-shaped) by for instance Composite Integration. These are in general used for RTM-light. The disadvantage is the ends of the seam: You will need to stick sealant tape to silicone, which can be tough.
-a step ahead is a double seam construction. (with sealant tape or silicone profiles). Between the 2 seals a very high vacuum is applied, which acts as a protection for the product vacuum. This is a very safe way.
With high precision moulds even round silicone profiles can be used in square recesses.
I have also seen bagging film around the outside of the flange, to create a double seamed flange.
Another system is to apply a gelcoat and skincoat into the mould, then infuse in the (airtight) skincoat. It is highly advisable to apply a high vacuum on the perimeter, to prevent the skincoat from lifting.
