had a thought the other day whilst making a mould (didnt turn out to good)
Is there any reason why you cant put your gelcoat on the plug then lay up the fibreglass dry (maybe a layer of woven first to give more chance of getting a nice uniform surface) the infusing the resin?
Any thoughts?
Also there was a post on the other site ages ago which has been deleted :roll: about using mircoshpere’s (i think) mixed with resin to put in corners to smooth them out when making a mould so the fibreglass didnt bridge.
Has anyone saved the webpage or made it available off line? If so can you post it on here or can someone confirm its microspheres not bubbles to use ( or the correct things to use)
