Anyone regulary using this product,?
Not used it yet but it’s on my next order to ECF
Same here im wondering if you use the peel ply still or just use that ?
In theory, looks great. Because they are bonded, you can cut to shape as needed, add bits and pieces to compensate for part geometry. The DM won’t slide around the film AND, the edges won’t curl
(so they say) No real need for peelply unless you want 1: bonding surfce 2: smoooooth surface.
So i can add my peel ply as normal if desired. This will be a good product as i got few compex shapes coming up
Yeah deffo go with peel ply to leave a flat textured surface. Release film tends to crinkle under vacuum.
Yeah. I kind of describe this as, the peel ply is another layer in your composite that you peel off, to leave a fresh surface. All the resin wrinkles are ripped off the top.
