Info thick layup 1in large 22ft long infusion
Hi
I need to know the best way to build up a spar. I will have to do a 60ply layup from a carbon tape 1inch large (by 22ft long), all in infusion. I will used a linear infusion method, so 1 full length of tubing injection resin to cross 1 inch of carbon layup,
with a resin break peelply of 2inch the other side. So question is :
1- To having a flat section to bond properly, do I put a caul plate on top of the
layup ?
2- Is using a 5/8inch large spiral tubing will be enought or an infusion mesh
will still be needed… ? I just need to travel 1 inch, but … better than a 3/8 tube…?
3- I don’t know if i do a layup over a flat surface : is the corner of it will bend, due to the bagging… ? Or then, the better might be to do the layup in a trench… mold type. But with a trench, is the tubing placing on top will be able to infuse the bottom of the layup…?
Thanks for tips.
do a test first… Sounds like it shouldn’t be a problem but if you do a smallish section, like 2 ft long first, that should answer most of your questions.
I would think it’d wet out fine. But the test will answer that question definitivley and you’ll have proof in your hand as well as a piece to do some destructive testing on if necessary. Then you can measure for flatness, thickness, weight, etc.
Not sure what you mean about the corner? This is a completely flat spar? Or do you have a flange to bond to?
Do you have an illustration of the mold idea?
Hi
Indeed i plan on a test, but I think may might have already done this. So here is the schematic of what i mean. As option 1 is a flat section. And the corner, being the side, might be deform due to the pressure…?
The option 2 might give a flat top, but i will not be able to monitor if it get infused properly. As to see the flow front…
Option3 could be in a mold as a L shape. But not sure if the bottom right will be infused right… ? No matter if resin input on top or at left.
It’s only a flat spar and i will do the flange later, not sure how by infusion…
your caul plate idea would work, though it might be difficult to keep your stack and caul plate all where you want in a straight line. Not sure what your tolerance is for straightness and flatness but it might make sense to actually have “walls” on LE & TE sides of the SC. This is how wind blade SC are usually made. It would keep your SC straight as you want and you dont need a caul plate (but could also add this in if you did it right)
Thank Hojo.
But if the fiber is put into a channel, how do it place the tubing. Having only a 1inch size tape, that might end up resin going to the output tube straight up to the catchpot… ?
