Hi
I would like to know the proper way for longterm storage. The plug will be made as
expanding foam over alu extrusion and mdf frame and cover with an Epoxy tooling coat.
The mold itself will be made with epoxy with 4 ply of fabric and perhaps some mat
all around. Flange made of small mdf as well. And stiffner will be in wood and Alu extrusion for the frame.
So if i do 1 part using the mold and store it outside after :
-Does the best way is to put the plug back in ?
- Is a simple covering canvas can be enought ?
We got snow and -25 to +25 outside over the year. Is 2 years later the mold will still
be ok … Or the alu extrusion will cause some compression due to thermal and resulting into a twisted mold ?
Many thanks
