What are the minimum and maximum recoat times on the clear coat?
Im using a fast activator and when I set up the bag with the laminates, its not tacky at all anymore. the one I made yesterday was allowed to cure for 2 hours in the sun (molds are black so they got up to 100f)
Are you degassing the resin?
Yes, but to be fair my vacuum pump has seen better days so it never pulls a ‘full’ vacuum
Has the resin been thinned? i.e. Does it have high solvent content?
no, but it is a very thin resin - sp115
Why are you wetting out the cloth out of mould?
this is more of a production thing - it is much faster for me to do the main wet out outside of the mold, lay the laminates up, and then do some extra wetting out inside of the mold
Are you consolidating the laminate stack before bagging?
I’m not sure what you mean by this. I am laying up multiple dry plies of fabric and then wetting them all out on a flat surface all in one go, and then laying them into the contours of the mold. i’m insuring that the resin soaks through, or at least the best I can. the ‘bottom’ of the laminate stack appears to be as wet out as the top when I do this
How much vacuum?
honestly I don’t have a proper gauge so I can’t tell you specifically but it’s definitely not a full vacuum. one of my problems is that i’m using stretchlon so I have to have some amount of vacuum, otherwise the bag doesn’t full compress corners down.
Gel time?
no gel time, essentially immediately after wet out (10-20 minutes) I set it up in the bag and pull a vacuum
Time under vacuum?
quite a bit, i’m working outside in very variable weather conditions so I usually let it sit under vacuum for hours to insure a decent cure before shutting the pump off, at which point it immediately goes to atmos. pressure (stretchlon… can’t hold a vacuum worth garbage)
I really want to go the wet lay and bagging method to work but at this point i’m considering trying a vacuum run. trying to get my hands on some mti hose but for right now i’m going to settle with the old school spiral and single point draw method
Chetan
