Hello. I know this may be an aggressive first post but bare with me. I’m not new to this forum and have been around quiet awhile. I’ve read through a number of threads about IMC but nobody actually helped to much on the process if you don’t want to use automotive clear. Here’s my issue.
I’m trying to use a IMC because the part I’m making has a kevlar surface. It’s a multipiece mold as well. Typically I do carbon fiber surfaces and I use 6k fabric, and tack the layers with spray glue. This isn’t an issue because I wet sand after demolding and post curing so I sand slightly into the weave, but not to much and never enough to hit the second layer of carbon since I use 6k. After the clear my part turns out great with no traces of super77.
Now my issue is that I’m using kevlar for the first time which I don’t think I can sand, even slightly because it will fray? I typically use 400 grit sandpaper on carbon and then clear without issues. I’m afraid to use it on kevlar because it will fray and ruin my part.
Now I know some people suggest gel coat, and let that tack to use the first layer, but I thought maybe I could use epoxy? I use Adtech 820 which is UV stable and I thought about maybe spraying that on my surface with a hvlp gun, letting it tack and use that as my adhesive for the first layer.
I wouldn’t be clear coating these parts afterwards, but I would be wet sanding and buffing since my molds not perfect. It is pretty close to perfect but some of the seams are sloppy and I’ll need to knock a MM down or so.
Any advice on what to do or input would be greatly appreciated. I’m trying to not use super77 and I need some type of tacking agent in my first coat. I know DDcompound has a nice IMC but it’s just to expensive for me…
