This is what I’ve been using so far. It’s not bad but I’d like a lil’ bit more working time if possible. Most boatbuilders I know of can get tent temps in to the 130 deg F range but not much more.
Viscosity: 500 to 770 cPs Mixed at 25oC
Mix Ratio: 100 parts A to 50 parts B by weight or volume
Working Time: 90 to 100 minutes at 454 Gram Mass
Peak Exotherm: 90oC
Time To Reach Peak: 120 Minutes
Density: 1.10 g/cc Cured
Full Cure: 4 to7 days at 25oC
Heat Cure: 2 Hours at 100oC
Set-To-Dry @ 10 Mil Film:  8 to 9 Hours
Surface Dry: 12.6 Hours
Mechanical Properties
Hardness: 75-80 Shore D
Izod Impact: 0.3 ft-lb/in
Tensile Strength: 10,900 psi
Elongation @ Break: 2.9 %
Tg: 65.8 oC
Tensile Modulus: 517.5 kpsi
HDT: 81oC @ 66 psi
Flexural Strength: 17,000 psi
Flexural Modulus: 546.0 kpsi
Compressive Strength: 12,800 psi at failure
Tensile Shear Strength: 4,400 PSI
T-Peel: 2.6 pli
Weight Gain After 2 Hour Water Boil: 1.3 %
