I’ve been meaning to post some pics of a standard infusion method with peelply delay. In these photos, everything is straight forward, and I hope easy to understand. Distro media is smaller than the part, and covering the inlet. Peelply is bigger than needed, but shows you the delay area. This allows air to leave the part, and when infusing, it lowers the risk of sucking up resin, it also allows the microvoids in the tows to get saturated, and the resin to continue to flow, albeit slowly. Bagging shows pleats on the opposite side of the tubing. None are needed perpendicular to the tubes, since it’s a thin part. Bagging is also on the large side, I didn’t do this part. Peelply is also covering the spirals, so the edges don’t cut the bag.
Caul plate infusion is the same, except add a plate on top (same size, or slightly smaller than part), and don’t use any distro media (except maybe around the infusion side. I use peelply around the infusion and vent side, just covering the corners of the plate.
Enjoy.
That’s the stuff I was talking about.
