Whats up everyone, I have been around this forum and seriously, there are so many great minds here and I enjoy being part of the community. I started last year making some composites plates, just flat, and non vacuum infused, however I want to start making parts with actual shape instead of flat panels now that I have learned a bit about the baby steps more or less of composites.
I have seen some setups, youtube videos, and also some suggestions here but I wanted to make my own thread to more or less get some guidance from the masters. The parts I plan to make will probably be no bigger than 2sq feet, and if I decide to get a little more eager nothing longer than the chin spoiler for a front bumper.
Of course, I need some new equiptment for this these tasks, as well as to make the molds themselves.
Q1: For the size of the jobs, for my first pump, would something like this be sufficient?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=98076
It seems well priced for the middle grade model that harbor freight is selling, but since this is my first, not sure if it has the power that I will need for vacuum infusion.
Q2: Is there any place you can send me, or show me how one would get a vacuum connector that mates up to these pumps, or is it pretty much going to home depot and matching a brass fitting up etc and attaching it to a hose?
Q3: Making the mold, I understand the basic process, however I am at a loss when it comes to material use. From what I have seen is generally you lay the part down on a surface, it then gets sprayed with generally a wax film, ontop of that is generally a film which is colored(I assume so you can see if you are missing any spots), after that is dry, applying fiberglass/resin to more or less make a shell which is durable. What exact materials are being used for such a thing, and can they be applied by brush, or have to be sprayed? (links to actual products would be awesome, but keep in mind this is my first vacuum infusion setup so the most expensive material is probably not a good idea for me)
Q4: Pressure pots, is the main objective of these to prevent damage to the vacuum pump incase the resin makes it through the mold and starts traveling through the tube heading towards the vacuum? I assume that is what they are for, if I am wrong I apologize in advance.
Q5: The parts I will be making will be either 100% carbon, or carbon for the face, and fiberglass backed, suggestions on resin? Right now I have gotten used to a 1:1 mixture doing everything by hand which has given me plenty of play time, but I assume for this type of work its more of a larger portion of resin and smaller amount of curing agent from what I have been reading? Any decent priced brands/types?
I first and foremost want to thank anyone who can help me answer my questions before I begin, I am doing this mainly because of my love of composites and wish I had gotten into it earlier. Thank you everyone!!
I’m watching your thread with great interest as I am in a similar position where I feel the need to take the next step to vac bagging and infusion, I’m following some posts on here from some guys in the UK who made their own pressure pots/seperators from drainage pipe and some fittings, hence the guage.
