Heres some really basic info as all guns are different.
Especially where the air control is.
The knob directly behind the needle controls the paint volume. Self explainatory as to what happens when you turn it.
The second smaller knob near it should control the fan. The width of the spray pattern.
Normally you want to keep the pressure at the gun, at less than 40 psi. Like mid 20’s. So you will need a pressure guage and pressure valve attached directly to the gun.
And let me be the first to say that a pressure pot set up is the way to go when dealing with catylized paints like those cured with MEKP.
